montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #1
fredshop2
juneau alaska
case
I would like to know the spec s of the pump and if any ones knows where to pick up a replacement
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #2
Welcome to TBN
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #3
Welcome to TractorByNet :tractor:
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #5
Are you looking for parts?
Do you want to replace that pump with something equal?
What is the HP of the engine driving the pump?
Can you show a picture?
Would you need a two stage log splitter pump to match your engine?
the engine is a 8 hp briggs and stratton I wanted to find a pump comparable I sent the pump no. some body out there may know the spec.s then i can try and locate a pump out there . any heelp would be apreciated skip
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #8
John S. Barnes was purchased by the Haldex corporation several years ago and now recently someone purchased them from Haldex so I suspect information on that pump may be hard to get.
I would check the front mounting features and drive shaft size and then find a pump like J_J references with these same features.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #9
If the pump above will not fit your pump mount, then select a pump mount from this list, observing the bolt hole pattern.
Most 8 HP engines are 1 in shaft.
You might need to change out the couplings. Lovejoy type, etc.
   / montgmery ward wood splitter hydraulic pump made by John S Barnes YF 717-0461 #10
oldnslo, Is John S Barnes on the river my state st, or is that W.F. & John Barnes?
UNUSED WOLVERINE TCR-12-48H 48" HYD TRENCHER (A54757)
UNUSED WOLVERINE...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
200722 (A51247)
200722 (A51247)
UNUSED (2) 3500# DROP AXLE W/ BRAKES (A54756)
UNUSED (2) 3500#...
