Montana T7074 PTO problem
/ Montana T7074 PTO problem #1
blueriver
Super Member
S.E.Oklahoma
JD 5520 Montana 4340 Farmall Super A Montana 5720C
Appears when the tractor gets hot the PTO will not shut off. Shut down the tractor and let set an hour and all works as it should. Then run a couple hrs and again it won't shut off. Anyone know if there's a valve, solenoid problem? It appears to be all electric. The switch checks out good and the lamp on the dash shows on and off .... Thanks
