Montana front end loader
/ Montana front end loader #1
donaldprice
Ky
Montana 3440 HST
i have a montana 3440 hst and the mounting bolts in the front end loader keeps coming loose i love this tractor its the only fault i have found i was wondering if any one else is having this problem.
/ Montana front end loader #2
I have a Montana 4540, bascially same loader/frame as yours. No, I haven't had any come loose, but I'm going to check them again, now that you have.
I did have 2 of the main FEL bolts shear off while pushing a big pile of brush in a low gear. /forums/images/graemlins/confused.gif
I've said it before and I'll say it again, The Montana 4540 has enough power to hurt itself. The 4540 engine should have been put in a bigger/heavier frame tractor.
James
i have no peoblem with that i have plenty of power i heard there are new mounting brackets to fix this problem tractor is still under warranty i hope i can get these and fix it myself
/ Montana front end loader #4
I wonder if this is a problem with all of the compact models or just your model? If there's a known problem and they have a fix, I would like to "fix/update" mine too.
James
/ Montana front end loader #5
I would just contact the dealer or call Montana directly. Montana is a company that works hard to see that every customer is happy and I'm sure they will address your issue!
Ken
i call montana tractors and talk to bob gontlz he told me there was new mounting brackets to fix the problem so im sitting up a appointment to get this fixed it may take a week or two to get this fixed but will post when it is done i really like this tractor and it seems like montana stands behind there tractor i like that thanks don
/ Montana front end loader #7
Bob Goltz is a great guy and Montana stands behind their products. Thanks for the update.
Maka
/ Montana front end loader #8
Do you know if the problem is with all compact models or just yours? Like I said before, if there's a known problem and fix, I want to update my tractor BEFORE I have problems. I have a Montana 4540.
Thanks!
sorry i really dont know
thanks don
got the mounting brackets and they were messed up pretty bad had to sand them down and repaint going to wait a day or two so it can dry will put them on and will post when i get it done
Don /forums/images/graemlins/smile.gif
/ Montana front end loader #11
Glad you got them. Montana is very responsive to customer needs. Let us know how it turns out.
Thanks,
Maka
Sorry for the delay have been sick. Just now getting to where I can work on tractor. Got the mouonting brackets on and really like the way they fit. The extra bolt holes should secure the brackets so the bolts dont come loose again. I put the right side on first and one of the transmission bolts had to be removed to put the plate on then I couldnt put the bolt back in if I would have none it I could have notched the plate out but I didnt have enought paint to repaint so knowing that I notched the plate out on left side. That worked perfectly. They only sent 2 cans of Montana green paint it wasnt enough to paint all bolts and brackets the right side is correct color and left is John Deere green. It's not really noticeable just slight difference.
Don /forums/images/graemlins/cool.gif
A picture of left side
picture of right side
2009 Vicon 2400 9ft. 3 Point Disc Mower (A65640)
2009 Vicon 2400...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
CONEX BOX (A65643)
CONEX BOX (A65643)
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
John Deere Grill Guard (A65640)
John Deere Grill...
