Montana 5720 losing power puting out hay if theres resistance
   / Montana 5720 losing power puting out hay if theres resistance #1
jcruce
Claremore
montana 5720
I have been having trouble losing power while putting out hay when I run into resistance pushing thru some mud and loose hay I also noticed it looses power going up hill in third gear two . I heard someone had similar problem and it was EGR valve . is it common to lose power if EGR valve is clogged.
   / Montana 5720 losing power puting out hay if theres resistance #2
You have an EGR valve????
   / Montana 5720 losing power puting out hay if theres resistance #3
The term "losing power" covers a lot of ground. If you mean that under load the engine RPM drops off, that indicates a fuel/supply problem. If it means the RPM stays up but the tractor speed slows, that leads more toward a clutch problem. I have no idea how an EGR valve would factor in, but I suspect that information may have been a reference to something involved with injection pump/emissions components. Not likely a factor in this case.
Impact Attenuator Guard Rail (A51692)
Impact Attenuator...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
7' Bush Hog 3 pt Mower (A50515)
7' Bush Hog 3 pt...
Hutchinson 10" Transfer Auger (A50514)
Hutchinson 10"...
(8) 75 lb IH Suitcase Weights (A50515)
(8) 75 lb IH...
