Montana 4940
/ Montana 4940 #1
LT-1
northern Minnesota
Montana 4940
Can't shift out of low range into high range. I very seldom us high range now stuck in low.
Differential lock foot lever will not move either. I never use the differential lock.
Any ideas?
/ Montana 4940 #2
A first guess would be corrosion due to lack of lubrication.
Buy a can of BLASTER and spray all the linkage until saturated, once each week for a month.
Park in sunlight when possible.
Then separate all the pieces comprising the linkages. Heat from a torch or heat gun will probably help. Grease pivots and bearing points; reassemble.
/ Montana 4940
Thanks. I will try that. Tractor sits is a unheated garage in northern Minnesota up to 8 months between uses. 2006 model turned 200 hrs today.
/ Montana 4940 #4
How many times in twelve years have you thoroughly lubed the tractor before leaving it to sit for eight months?
/ Montana 4940
At least every other time I grease it. Never thought about shift linkage. I won't pass it up again.
/ Montana 4940
A health spray of Seafoam deep creap. Tried shifting 5 minutes later and yea hah it worked.
/ Montana 4940 #8
More importantly...Lets see the LT 1 and what car it's in....
/ Montana 4940
I bought a rear ended 20,000 mile Corvette and put the running gear in my 54 Chev. I cant figure out how to put a pic on here. Drives like a dream. 26mpg on the highway or spin the tires about as far as you want to.
/ Montana 4940 #10
click that third from the right icon above the box you're typing in, click the 'choose picture', scroll through your computer to find the pic, then click it, then hit the 'upload' button and your pic will be there. In your box before you post, it will look like a link, but once you hit 'post quick reply' it'll show up as pics in the post for everyone to see :)
/ Montana 4940 #11
LT-1 i use a home made penetrant 1/2 acetone and 1/2 trans fluid shake good before spraying. It the best i have ever used.
Femac T9 70 REV Excavator Mulcher (A66285)
Femac T9 70 REV...
2005 GMC TOPKICK C6500 TESTING UNIT (A65643)
2005 GMC TOPKICK...
2010 48 ROLL OFF TRAILER (A65643)
2010 48 ROLL OFF...
Dexter trailer axles (A61567)
Dexter trailer...
Diesel Heater (A66408)
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
