Montana 3040 electric wiring for fuel shutoff solenoid
   / Montana 3040 electric wiring for fuel shutoff solenoid #1
concrete guy
Mathews, VA
montana 3040
Hello tractor guys, any buddy have a ny electric wiring diagram for the shutoff solenoid, I don't know if is a relay before the solenoid, I sill appreciate thanks in advance
   / Montana 3040 electric wiring for fuel shutoff solenoid #2
Did you ever get an answer to this question? I have a diagram.. I think will work for you. Its for a 3040 and 3840... Im using it for my 3440 but its not complete for me for what I need.
   / Montana 3040 electric wiring for fuel shutoff solenoid #3
Assistir, If you are still active... I would love to check out your 3840 wiring diagram. I purchased the PDF manual (download) for the tractor, but it doesn't contain the electrical schematic. My tractor is doing something similar to the Concrete guys. If I am running multiple electric components - such as the PTO solenoid and turn on the lights, it kills the engine. Or headlights, then hit the brakes (switch), it will kill over. I checked the grounds and connections that I could see. It is charging to 14+ Volts at idle. Even had a meter on it when I ran pto then headlights then hit the brakes. Voltage only dropped like .5 Volt. I am sure it's a worn out circuit breaker or a bad solenoid. Thanks for your help
   / Montana 3040 electric wiring for fuel shutoff solenoid #4
from the 3040 - 3840 service manual.
Gary
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
2018 Doosan DL220-5 Articulated Wheel Loader (A53421)
2018 Doosan...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A55301)
Adams Load Out...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
