montana 2740
   / montana 2740 #1
rfoster
pulling a five foot howse rotory cutter with 270 montana,
tractor keeps running hot. check belt, coolant, radiator clear.
any suggestions.
   / montana 2740 #4
any suggestions.
Are you sure the radiator is clear? had a similar situation and eventually had to remove the radiator and power wash between the fins. make sure you can seen through the radiator for most frontal area.
   / montana 2740 #6
A good horse power rule of thumb for rotary cutters is five horse power per foot of width. Five foot would call for a minimum of twenty five horse power at the PTO. The 2740 is rated at twenty seven tractor horse power. The PTO horse power will probably be between 18-20. You may try taking a three quarter cut and see if the problem continues. You may have to make multipile passes in tall heavy material.
   / montana 2740 #7
I also notice some heat issues. It makes a difference if I run in 1 high or 2 low.
RC
   / montana 2740 #8
I just bought a 2740 but haven't used it yet but had a similar problem with a Hinomoto E324 with a 6' cutter. If the radiator is old and the fins bend easy it may not transfer the heat very well. I Had mine recored at a local radiator shop. At the very least the can flush it and let you know. May be asking some questions as I start using mine. Good luck
434669 (A48836)
434669 (A48836)
2005 CHEVROLET SILVERADO (A52472)
2005 CHEVROLET...
100 GAL FUEL TANK W/ PUMP TOOLBOX COMBO (A52472)
100 GAL FUEL TANK...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
378788 (A51573)
378788 (A51573)
