Monkey Wards 8Hp 5Spd rear tine
   / Monkey Wards 8Hp 5Spd rear tine #1
kwbobwi
Central Wisconsin
Farmall A
I picked up a dinosaur Wards rear tine with a Briggs 8hp, Model #190402.
Long story short it's been sitting in a garage for many years, lucky me there is no spark, I cleaned the points, flywheel and coil, still nothing, so my questions are
1, What are my affordable options? it's in decent shape needing tires and what ever to get it running
2, Is there a solid state ignition available?
3, Will a Predator 8Hp be a direct replacement?
4, Would 8Hp snowblower engine be an alternative with a change of flywheel shroud?
Sorry about crappy pics, need a new clear cover for my case
   / Monkey Wards 8Hp 5Spd rear tine #2
I don't get what the pics are. Some odd thing with yellow lights on the top. :LOL:
Did you clean the carb? Coils do go bad sitting around.
Monkey Wards store #1 is about 12 miles from me. It's more like a history site. And WARDS does run their online site from there.
   / Monkey Wards 8Hp 5Spd rear tine #3
Monkey Ward's still around? I have an MW refrigerator from the '80s.
OP, there are replacement coils on Amazon and eBay for $15-20. Most are electronic. I put one on my dad's 5 horse vertical shaft tiller that wouldn't hold time due to a keyway issue. It starts better than new. You'll have to confirm the part #.
The lights are on the headache rack of my truck, I volunteer my time/gas to escort farmers for safety
The lower part shows the handles of the tiller, I said they were crappy but the best I have at the moment
   / Monkey Wards 8Hp 5Spd rear tine #5
I bet if you have a local small engine shop that has been around awhile, they would be familiar with that engine and have some ideas.
   / Monkey Wards 8Hp 5Spd rear tine #6
Briggs 398811 is the electronic replacement for that engine.
   / Monkey Wards 8Hp 5Spd rear tine #8
That very same B&S engine is in my front tine Sears 1976 rototiller. I still use it a couple time per season.....and it sets outside with a wash bucket over the engine. Starts right up every time with some fresh gasoline in the bowl/ tank. It is one great piece of equipment with lots of hours on it.
Cheers,
Mike
   / Monkey Wards 8Hp 5Spd rear tine #9
Make sure the coil is not grounding out before you start throwing parts at it.
   / Monkey Wards 8Hp 5Spd rear tine #10
Check the magnet in the flywheel to insure it is still good. Use a screw driver and insure the magnet grabs the screw driver. Use sand paper to clean the magnet area. Don’t get to abrasive with the sand paper you want to clean not polish. Then install the electronic ignition. Take the plug out and spin the engine by hand passing the magnet under the electronic ignition while holding the spark plug wire you should get a slight jolt.
Reinstall the engine shroud containing the pull rope after determining the rope is not rotten and will break the second time you pull on it.
2008 Chevrolet Impala LT Sedan (A55853)
2008 Chevrolet...
2009 IC Corporation PB105 School Bus (A55852)
2009 IC...
2011 GAYLEAN VACUUM 130 BBL VACUUM TRAILER (A55745)
2011 GAYLEAN...
2012 FORD F450 XL SUPER DUTY TRUCK (A51406)
2012 FORD F450 XL...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2020 Ford Explorer AWD SUV (A55853)
2020 Ford Explorer...
