Moline 2 bottom plow tail wheel
   / Moline 2 bottom plow tail wheel #1
slim357
Ford 4110
cant seem to get this to fit right. Any thoughts? DSCN0245[1].JPGDSCN0246[1].JPG
   / Moline 2 bottom plow tail wheel #2
looks like a hub is missing,
I got a few wheels off a old MM plow, I look at tomorrow, (mine was newer than yours, I think), but one could make a hub, from some DOM tube, and a plate cut in a circle with some holes to bolt the wheel on, drill a hole in it and tap it for a grease zerks, some washere one the end so it does not wear out the cotter pin that holds it on, the factory one usually had a cap on them that went over the end and the cotter key, the hub was long enough to fit up under the cap washer, so when dirt was pulled up around the wheel, it would not fall in the cast bearing.
most likely it similar to what the colter hubs are like if your plow still has the colters, on it,
thanks for the info. Its a fun project.
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E83NKE63062, Extended Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
Pnuematic Transfer Pump on Rolling Cart (A59076)
Pnuematic Transfer...
3PT HYD HAY FORK (A52708)
3PT HYD HAY FORK...
LOT: (2) Rolling Nut & Bolt Carts w/Bins & Contents (A59076)
LOT: (2) Rolling...
2012 LAND ROVER Range Rover SUV (A56859)
2012 LAND ROVER...
