PILOON
Super Star Member
The quality of gauges used in tractors could probably best be described as 'water resistant' and not 'water proof'.
Generally there is a paper gasket between the glass and shell which I'm sure is more of a vibration damper than a seal.
Looking at the backsides of most gauges you will always find some gaps that allow humid air and dust to enter.
On the plus side many, if not most, of the working innards are brass and the dials generally aluminum.
Downside is most printing fades with time.
Water and dust proof gauges would have them up into aircraft (jets) quality instruments and the dash would be worth as much as the tractor.
FYI, many small aircraft (Cessna, Piper) gauges (RPM, temp, pressure) are simply adaptations of your common tractor (automotive) gauges.
Even the fuel gauges use the typical cork float technique in the sender unit.
