Moisture in instrument cluster
/ Moisture in instrument cluster #1
FortClatsop
Astoria Oregon near the winter quarters of Lewis &
2006 JD 2305, X540, X324, 314, 316/33 tiller
Here on the coast moisture is always a problem. And corrosion always follows moisture. Shortly after receiving my 2305 last march I noticed condensation in my instrument panel. My dealer said that that it was not a sealed unit and it would eventually clear itself. On hot dry days it was gone. On any cool overcast day it would reappear. Being leary of corrosion I asked my dealer to replace it.
About six weeks ago it was replaced and my little beauty sleeps inside, snug and dry. I've been using it again in cool damp weather and lo and behold....my new instrument cluster is having moisture condense inside it. Feeling foolish, I discussed it with my dealer and his mechanic. They said they knew it would do that. And so did the John Deere Rep. I guess that it is a function of tempature, humidity, and dew point. Does anybody else have this happen or is it because everything else I own is rusty, my house is mossy and I have fungus growing on me. It's Oregon isn't it?
/ Moisture in instrument cluster #2
I have a 2305 in the NC and does the exact same thing.
/ Moisture in instrument cluster #3
I am in the Northwest, but on the supposed dry side of the Cascades and low and behold, I am also a recipient of the moisture in the instrument panel on the moist days. I have already removed the instrument panel and used vaseline to try and lubricate and seal the rubber gasket on the plastic panel to no avail. I am at a loss with the rest of you. If John Deere knows of the problem, why haven't they addressed this problem??????
/ Moisture in instrument cluster #4
My 4110 get this occasionally...
/ Moisture in instrument cluster #6
As long as the air has a way to get into the cluster, such as thru a light socket, some of it will carry humidity. They could replace the lights with leds but then you would have to replace the whole cluster if one burnt out. Its easier to build things out of plastic or coated metal so the moisture doesn't bother it----for a few years...
/ Moisture in instrument cluster #7
Hmmm... have a 17 year old D 670 that has always remained dry inside. Stored in the barn, but wash it with a hose even on the instrument panel. But just got a new 2320 and I'll have to watch for the moisture issue. It's humid here in MO but maybe dry enough at other times?
/ Moisture in instrument cluster #8
So far the instrument cluster on my 2320 has stayed dry. That has been through one pressure washing and a rainstorm that came from the wrong direction and blew underneath my shed roof. I'll sure keep an eye out though.
/ Moisture in instrument cluster #9
Did not see that on my 4100, have not noticed yit yet on the 4310, even after soaking the crap our of both 'chines while washing them
/ Moisture in instrument cluster #11
Yep, same here in Coquille on the southern Oregon coast. My JD is a model 4200 and was told the same lame story by the dealer.
/ Moisture in instrument cluster #12
The technical name for the cause is "dinural pumping". The communications waveguides (WG) I deal with could have it... if I didn't take steps to prevent it. Basic action is: Air filled chamber heats up over the day. Causing air to expand, and it pushes out through any opening. After the sun goes down the chamber cools off, causing the air pressure to go below atmospheric which causes the air to be "sucked in". Problem is that the thermal mass of the chamber walls (and attached enclosure/tractor/?) does not cool off as fast as the outside air. Since the outside air temp is dropping, the relative humidity is going up, so the air drawn in is moisture laden. As the night continues to cool down the moisture now inside the chamber condenses and forms water droplets. The next day the chamber starts to heat up forcing air out again. The heat necessary to vaporize the water lags behind the heat necessary to force the air out, so the chamber becomes saturated. The cycle keeps repeating. We have multiple O rings and seals on the WG and it still happens. The way we keep it from happening is 1: We pressurize the WG with either dry air or nitrogen to 2-4 psi (some more, some less). It just has to exceed the differential pressure created by the heating. 2: we install a desiccating plug. This device is a hollow pipe (about the size of a screwdriver handle) filled with desiccant. As the air expands (remember it is dryer now) it dries out the desiccant on it's way out. As the air starts back in the desiccant drys it out. Since it is easier for the air to travel through the plug it leaves the other seals intact.
More than you ever wanted to know. :) My 4300 did the moisture thing as does the 4520. I'm thinking of installing a desiccant port on it.
/ Moisture in instrument cluster #13
Park it in the sun for an hour or two before you put it away and the moisture inside your instrument panel should evaporate.
/ Moisture in instrument cluster #14
Cidertom said:
"dinural pumping".
More than you ever wanted to know. :) My 4300 did the moisture thing as does the 4520. I'm thinking of installing a desiccant port on it. (post #12)
Hi Cidertom: Thanks for the informative post! I have considered taking my JD 4300's instrument cluster apart and putting in a small desiccant bag. Does anyone know if there is any room in there? I think that the port would work better. Where can I get a desiccant port?
Thanks, Marshall
/ Moisture in instrument cluster #15
I will look through my suppliers cat today and see what I can find for the 1-2 buyer. One other thing that >might< work is to put drain holes in the lowest part to allow the mositure to escape. That works for the tower mounted boxes, they have a coulpe of 8-32 sized holes in the bottom and they stay dry. While the moisture might still form, the holes being at the low point would let it get back out.
/ Moisture in instrument cluster #16
What about a 12v light bulb attatched somewhere out of site but dissipating heat into area (on all the time key on). Maybe this would keep things warm/dry enough to eliminate problem. I know a brake light bulb can get plenty hot if it's on all the time.
/ Moisture in instrument cluster #17
Whatever the fix is I wish someone would let JD in on the fix. This same problem has been going on for a few years now and they don't seem to care. Same thing with the fuel gauge...
1993 CHEVROLET Corvette (A59231)
1993 CHEVROLET...
2012 BMW 328i Coupe (A61569)
2012 BMW 328i...
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
(INOP) JOHN DEERE 9420R ARTICULATING TRACTOR (A64280)
(INOP) JOHN DEERE...
Year: 2015 Make: Chevrolet Model: Silverado Vehicle Type: Pickup Truck Mileage: 83,704 Plate: Body (A61573)
Year: 2015 Make...
2015 Ford F-150 Ext. Cab Pickup Truck (A61573)
2015 Ford F-150...
