Modulated PTO engagement on CUTs?
/ Modulated PTO engagement on CUTs? #1
bam747
Palmer Divide in El Paso County, Colorado
John Deere 4720 (2007)
Which mid and full frame CUT brands have fully independent and modulated (soft, feathered) engagement for their rear PTOs?
I'm talking about the ability to slowly engage the PTO even while the motor is running at its full 540 RPM PTO rated speed. This PTO engagement can be manually modulated by the operator or electronically controlled and must be fully independent from the transmission clutch or hydro transmission.
I've seen some other posts here on TBN indicating that many of the CUTs only have a "slam it on" all or nothing PTO switch and the best practice seems to be engaging the PTO only at slow (near idle) engine speeds. That would seem to be a big issue for PTO driven implements with large rotating masses (rotary mowers, small square balers).
/ Modulated PTO engagement on CUTs? #2
The larger Massey Ferguson compacts have had soft engagement for several years. The 1200s and the 1400 had a two stage engagement. The new 1500 has a separate switch that feathers the PTO in.
/ Modulated PTO engagement on CUTs? #3
"I've seen some other posts here on TBN indicating that many of the CUTs only have a "slam it on" all or nothing PTO switch and the best practice seems to be engaging the PTO only at slow (near idle) engine speeds. That would seem to be a big issue for PTO driven implements with large rotating masses (rotary mowers, small square balers). "
I'm not sure why engaging the PTO driven implements at a low RPM would be a big issue. It's just a matter of having your transmission in neutral, engaging the PTO at a lower RPM (1200-1500 RPM) to reduce the shock load to the tractor's PTO, then increasing the RPM. That takes less time then it did to type the preceding sentence.
/ Modulated PTO engagement on CUTs? #5
I know the poster said CUT.. but just to relate.. the IND pto on my NH 7610 has a feather engage.. but still reccomends you idle down before doing that to prevent wear to the pto clutch.
Soundguy
/ Modulated PTO engagement on CUTs? #6
</font><font color="blue" class="small">( Does it even have to be in Neutral to engage? I think mine (JD 4110) goes on or off without leaving low range? Am I risking damage by doing this? )</font>
No, it doesn't. I'm in the habit of having my 790 (gears) in neutral when engaging the PTO. I leave it in neutral until the cutter blades rotate for a few seconds...Land Pride's manual says 5-10 seconds, if I recall correctly.
I do think it's safer and easier on the tractor if one is in neutral when engaging the PTO, but that's just my opinion.
/ Modulated PTO engagement on CUTs? #7
I think the PTO on JD CUTs is engaged with a solenoid. Just throttle back to around 1500 rpm and pull the button. On my Gravely, I got used to slowing it to idle to engage its all-gear PTO. Same thing. You can actually engage the Gravely PTO at speed by throwing both forward/reverse lever and high/low levers into neutral. However, you gotta make dead sure both levers are truly into neutral; otherwise, you'll grind gears.
My neighbor's old JD 820 PTO engagement seems much like that on the Gravely: purely mechanical. Gotta throttle back to engage it. Not sure whether the clutch can be used to feather it. Think the clutch only engages the ground speed box.
Ralph
/ Modulated PTO engagement on CUTs? #8
90% of the time i have mine in netural efor engaging PTO( but really don't think it is necessary, just push in the clutch, RPMS low and engage PTO and bring it up to PTO speed, just the reverse before disengaing the PTO. always with the clutch in
/ Modulated PTO engagement on CUTs? #9
</font><font color="blue" class="small">( I do think it's safer and easier on the tractor if one is in neutral when engaging the PTO, but that's just my opinion. )</font>
I don't imagine having the tranny in neutral will affect an Independent PTO whatsoever.... My transmission clutch does nothing to my ind pto.... That's why they call them independent...
Even on a 2-stage clutch setup... I never shifted to N.. just depressed clutch to 2nd stage to engage.. then slip and go..
Soundguy
/ Modulated PTO engagement on CUTs? #10
On my Kubota L3130 I have a lever switch for the PTO. If you flip the lever over to engage the PTO it will work like a "slam it on". If you slowly move the lever over it will gradually engage the PTO. I usually throttle down to 300-400 RPM's when engaging the PTO and it does not matter if it is in gear or in neutral. The manual also states to slowly move the lever over to engage the PTO to prevent the "slam on" effect. This would be the same for L3130 - L5030.
/ Modulated PTO engagement on CUTs? #11
The PTO engagement on our Kubota Grand L-3130 GST is modulated in direct proportion though how fast you engage the PTO lever and is completely independent of the transmission, as are all of the other Grand L series..
/ Modulated PTO engagement on CUTs? #12
</font><font color="blue" class="small">( PTO it will work like a "slam it on". If you slowly move the lever over it will gradually engage the PTO. I usually throttle down to 300-400 RPM's when engaging the PTO and it does not matter if it is in gear or in neutral.)</font>
On my Nh 7610s.. If I just moved the pto engage lever straight over I'm sure it would slam on as well.. but as you mentioned.. if you 'feather ' it over it does a gradual engage.
Wow.. 300-400 rpm... I can get that low on my old gas jobs.. but my diesel doesn't like idleing that low!
Soundguy
/ Modulated PTO engagement on CUTs? #13
The 300-400 RPM speed was the PTO speed, the tractor speed is around 1300- 1800 RPM. I re-read my post and that was not very clear /forums/images/graemlins/crazy.gifsorry.
/ Modulated PTO engagement on CUTs? #14
To all. The way the feather engagement works on the Massey 1200s and 1400s is that there are two solenoids. The primary solenoid is energized for as close as I can remember about a second at half pressure. Then the secondary is engaged is at full pressure. This prevents the sudden or harsh engagement that some here have had such as when using brush hogs and shearing shear pins. The 1500s have had it changed somewhat. From what I can gather, you can set it to where is engages even softer. As far as taking it out of gears to do this, you don’t have to. This is a fully independent PTO.
/ Modulated PTO engagement on CUTs? #15
On the kubota L30's you can feather that lever or on hydro models at least feather the main clutch to save wear on the pto clutch.
I use the main clutch to engage the baler slowly, the PTO lever for most everything else.
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
Ford 8210 (A60462)
Ford 8210 (A60462)
2017 Skytrak 10054 10,000lb 4x4 Rough Terrain Telehandler (A59228)
2017 Skytrak 10054...
207281 (A52708)
207281 (A52708)
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2023 JOHN DEERE 85G EXCAVATOR (A59823)
2023 JOHN DEERE...
