modifying lawn tractors
/ modifying lawn tractors #1
glover
peterrborough ontario canada
MF 165 and CASEIH JXU90
has anyone made made implements for riding mowers such as snowplows wheel weights or made snow chains
/ modifying lawn tractors #2
Almost anything within reason will plow snow, heard of guys using old water heaters cut in half, planks ect. All will move snow just that some do it better than others, I made a 7' for the CUT, then modified a 7' meyers that I now use and cut the other one down for dozer use only. As for tire chains we modified anything we had laying around, got a set of tractor trailer chains downstairs I am modifying to go on the 11.2x24's, one can do just about anything if you have some basic elements, time, money, ability, desire, knowledge, and of course equipment.
/ modifying lawn tractors #3
I have adapped chains it fit many difernt size tires. Thats an easy one. and cheap. You can find a nice set of'fits God knows what" chains everywere for cheap.
I also made up a set of front wheel weights for one of my Ingersoll tractors. So far they have worked AWSOME.
/ modifying lawn tractors #4
Anything's possible. If you want any suggestions, post your ideas here. I'm sure someone will have an opinion and some good advise!! /forums/images/graemlins/smile.gif
/ modifying lawn tractors #5
absolutely,thats the best part. making your own stuff, from putting small diesel engines in L&G tractors that have bad engines to making attachments. i recently made a sulky for the wife with a small little wood flat bed in the back to haul all the junk we buy at shows. and made a tandem seat for jr that can be attached to the back when he is with us. i tried to post a pic, but my camera doesnt resize down small enough.
/ modifying lawn tractors #6
i would imagine that a lot of folks have made very many things, and if you can imagine it, YOU CAN MAKE IT.
/ modifying lawn tractors #7
<font color="blue">...i tried to post a pic, but my camera doesnt resize down small enough.</font>
Try IrfanView.com software. It's a free and safe download. Gerard
/ modifying lawn tractors #8
Check out the " build it yuorself " discussion and " machine builders network ". Someone probly done it.
/ modifying lawn tractors #9
Here's a picture of my Ingersoll 224 that I put 4wheel AG tires on, homemade front wheel weights, and a modafided front weight box to offset the weight of the log splitter on back. Also added a hydrolic filter to it. The Ingersoll [and older Case] tractors are powerd by a true hudrolic system, but stock they came with no filter.
/ modifying lawn tractors #10
</font><font color="blue" class="small">( has anyone made made implements for riding mowers such as snowplows wheel weights or made snow chains )</font>
I BOUGHT A NEW BLOENS IN 1966:
It's on the 3rd. set of chains i made out of old tire chains for a car.
/ modifying lawn tractors #11
Glover,
This is an easy and very inexpensive one for you. I made this up real quick when I needed to mow some hills. I pruned off the conduit for a flush fit later and painted the wheel weights. To make a higher quality solution, I planed on using a 1" size bolt and a crown nut to hold things together, but this has been working now for a couple years /forums/images/graemlins/smile.gif. The groucho glasses are my disguise when running the Craftsman /forums/images/graemlins/smile.gif.
/ modifying lawn tractors #12
made this sulky with slide in tandem seat for the wife and jr. beats walking at all the shows, and hauls all the junk ya buy on the back.
