Modifying a Hydraulic Cylinder
/ Modifying a Hydraulic Cylinder
Junkman
I didn't modify the blower at all - just removed the rod arrangement they had there and replaced it directly with the cylinder. Once the cylinder fit it was a direct swap except for the need for 3/4 to 1/2" bushing to adapt the holes that were there to make them fit the pin of my cylinder.
I don't know what a BX blower looks like, but the one for the 3010 has a sort of triangular bracket on the deflector assembly and I just used that.
/ Modifying a Hydraulic Cylinder #22
Great work on the hydraulic cylinder!! I build my own cylinders though. I get all the supplies from Baily.net then weld everything together. Fast, simple, easy. I can custom size all stroke and cyl sizes I need. Your way was indeed an education. One can build tie rod cylinders with out welding also. Just assemble all the parts and tighten the bolts. /forums/images/graemlins/cool.gif
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
Snap-On Zeus Diagnostic Machine (A63689)
Snap-On Zeus...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
