Modifying a Bale Spear?
   / Modifying a Bale Spear? #1
teg
Super Member
nowhere
s
I want to lighten a Bale Spear, it weighed 250 lbs. I unbolted the old brackets and would like to weld new bottom brackets that will lower the overall weight by 100 lbs. As a side bonus, I can bring the hook up points 2 inches closer to the tractor (when you talk about a half ton, that adds up, (I think :confused: ) ).
Questions, Will it be strong enough? and does it matter which way the brackets go? I know I can reverse the pins later but would like to know if one way is stronger, my gut says to the left (But if it's not welded good - it really doesn't matter which way, eh? :D).
(I have a question in the attachment section on if I should just sell this but I would still like to know if you guys think welding the brackets a certain way works better or not).
   / Modifying a Bale Spear? #2
I usually mount mine with the pin pointing out because my draft links swing out freely. It makes it a little easier to hook up without adjusting the sway links.
I have bent a few angles mounted in this configuration however a small gusset, maybe 2x2 or 3x3 welded on the bottom or top of the angle should give it all the strength you need.
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2013 JOHN DEERE 8235R LOT NUMBER 205 (A53084)
2013 JOHN DEERE...
