Modifying 3PH To Allow Tilt AND Down Pressure?
   / Modifying 3PH To Allow Tilt AND Down Pressure?
That looks like an excellent application for down pressure. Just a tad of down pressure would help get that last bit of packed snow, ice or slush off the road or parking lot. It's interesting to me that so much technology is developed overseas.
https://www.youtube.com/watch?v=bFFkQVu5RWg
Another video showing the down pressure in use.
Can even be done with a Dodge.
https://www.youtube.com/watch?v=lqeMCTEj648
http://www.tractorbynet.com/forums/hydraulics/94755-hydraulic-down-pressure-3-point.html
3-point hitch - Farmboy | UTV Hitchworks - Maineville, Ohio
   / Modifying 3PH To Allow Tilt AND Down Pressure? #12
i could really see use for say a post hole digger on a 3pt! ewwww mind is wondering again... i could see use for a disc harrow use as well. just a little bit of weight off of a few thousand lbs tractor... *big eyes* yums!
   / Modifying 3PH To Allow Tilt AND Down Pressure? #13
Why this is used is to reduce the weight, before you loaded your ice blade with weights or used a real grader but those are expensive and not as versatile as a tractor, here in Norway a lot of farmers earns good money on winter road maintenance, and for those that thinks it must be a slow way of doing it, most tracktors goes in 50 km/h or even faster.
   / Modifying 3PH To Allow Tilt AND Down Pressure? #14
Some Zetors and Ursus ( and probably others ) have factory down pressure on the 3 point hitch, it will just lift the rear wheels of the ground if you put blocks under the arms.
I use my Kubota 3 point hitch ( no down pressure) to tow trailers, because it is so easy to hook up. The downside is however if I load on the back of the trailer, or if I back up pushing the trailer against a bump, the 3 point hitch lifts up and the top link smashes the cab of the tractor.
I wish I had down pressure!
Bert.
2003 Big Tex 10PI...
2020 JOHN DEERE 700K LGP CRAWLER DOZER (A52707)
2020 JOHN DEERE...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
1987 Ford F800 E-One Pumper Fire Truck (A55852)
1987 Ford F800...
2023 Vivid EV Electric Cart (A55853)
2023 Vivid EV...
