Rotary Cutter Modify Rotary Cutter
   / Modify Rotary Cutter #11
As Soundguy said, the rear of the mower should be high, it's not supposed to do the cutting. Adjust the tailwheel to give you plenty of clearance.
Ken
How much higher should the rear wheel be? Right now it is maybe an inch or two higher than the front. As stated earlier, I am getting a really nice cut with the mower at it's current height.
   / Modify Rotary Cutter #13
It shouldn't hurt to bring the rear up another inch or two. :)
   / Modify Rotary Cutter #14
yep.. few inches total. not much more.. just a few.. 2-4 IMHO.. should be fine depending ont he specific mower geometry.
larger ( longer ) decks will need more. IE.. a 7' SB mower will need a lil more rise back there than a 4' mower.. etc. 4" on a 4' mower would liekly be too much.. etc.
soundguy
Caterpillar 259D (A53317)
Caterpillar 259D...
2024 CFG Industrial KRW232 Mini Wheel Loader Skid Steer (A55851)
2024 CFG...
Cushman Electric Utility Cart (A55851)
Cushman Electric...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A54811)
2016 Toro...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A55852)
2012 Chevrolet...
