Modify a bucket to carry more firewood
   / Modify a bucket to carry more firewood #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
Has anyone made a rack, wood extension, or whatever that would allow a bucket to carry more firewood. With my woodstove I find I am moving a lot of firewood. I could make it out of wood or metal. I also have a hydro tank that I could use. Any suggestions would be appreciated.
   / Modify a bucket to carry more firewood #2
This has been discussed a few times. Here's one:
http://www.tractorbynet.com/forums/...ng-firewood.html?highlight="bucket+extension"
There was a good suggestion in a thread august 2007 but I can't find it any more. Maybe its in the attachments or customization forums.
Anyhow the guy used 1/2 inch plywood, 2x4, furring straps and straps to make a removable extension. I can post the picture if you, or others, can't find the thread.
Later - I changed my mind and decided to attach links now. Here they are
felbucketextension2.jpg - Image - Photobucket - Video and Image Hosting
felbucketextension.jpg - Image - Photobucket - Video and Image Hosting
That's what I was looking for. Thanks, good pictures.
   / Modify a bucket to carry more firewood #4
I've been thinking of making one of those. Only I'd make the bottom of 3/4" and the sides and top of 1/2" plywood. The 2/4's would be a couple inches longer than the plywood bucket so that when the thing is stored upside down, it'd be off the ground.Instead of bolts, I'd like to try using 12ft straps.
It's not obvious in the picture, but I think that the bottom sheet goes full length into the bucket, while the sides and top are only to the lip of the bucket.
I figure that it'd be easy to install. Just put the bucket over it like a hat and tie the straps. Another project of mine involves staining a deck and I think that leftover deck stain would help preserve it.
If you use bolts, don't forget the trick of using a step drill bit for the bucket holes.
   / Modify a bucket to carry more firewood #5
Am I the only one that carries the whole log to the pile and hold it with my backhoe while I cut it, then pick it up and plunk it on the stack? I don't get why you'd cut it, then carry it to the stack only to re-stack it again.
As usual, I'm probably missing something.. :)
   / Modify a bucket to carry more firewood #6
You probably have a short easily travelled distance between your logging site and the wood pile. Try winding your way with your tractor between the trees while towing a log.
Or you can cut and split on site.
   / Modify a bucket to carry more firewood #7
You hit the nail on the head. Mine are fairly close and easy to get to.. Didn't think about a trip thru the forest..
   / Modify a bucket to carry more firewood #9
I built something similar to the Carry all device . except mine was a piece of plywood the wide of approx the depth of the bucket it would set against the bucket lip almost flush. the sides were also similar to the carry all idea except the side come back into the bucket side more. and then have a bolt that goes through the side of the bucket to hold it on.
this works so well, that I replaced the bolt with a bolt and a huge wing nut.
I will try to post a pic
   / Modify a bucket to carry more firewood #10
We have tons of 10" and under trees. We drop 'em and drag 'em to a central location and lay them next to each other. Then I use my forks to lift 5 or 6 of them up at a time from the middle and cut off 16" pieces pretty fast this way.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2012 Freightliner M2 106 Braun Ambulance (A51692)
2012 Freightliner...
2018 HONDA RECON 250 4-WHEELER (A51247)
2018 HONDA RECON...
2020 KENWORTH T680 TANDEM AXLE SLEEPER TRUCK (A53426)
2020 KENWORTH T680...
2022 BOBCAT T64 R-SERIES SKID STEER (A51246)
2022 BOBCAT T64...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
