>>> MODIFIED TEMPORARY TOWING LIGHTS <<<
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #1
BearKiller
I have been carrying around a set of Harbor Freight 96933 magnetic towing lights for a few years, un-used, and still in the package, just in case I should ever have reason to tow something that did not have decent lights.
I did cut a hole in the package, fish out the pig-tail, plug it in, and test them.
This morning, before day-light, just such an occasion did occur.
I had to return a rented Kubota B20 back-hoe, along with the complimentary rental trailer to haul it on.
As such stuff goes, every light on the trailer was busted; the pig-tail had been drug on the blacktop so many miles that it was sanded flat through three of the six sockets; and, chewed-up wires were hanging all underneath.
No problem; I dug out my set of magnetic lights and put them to use.
Two things quickly became obvious; the magnets were just a shade on the wimpy side and each wire was an individual wire, not all neatly bonded together as I had expected.
The magnets did manage to keep the lights in place, but I still wasn't impressed with them.
And, something was definitely gonna have to be done about that potential rat's-nest of wires.
Several feet of 1/4" and 3/8" split wire loom, plus a bunch of zip-ties, took care of the rat's-nest problem.
The supplied magnets set in a form-fitted plastic socket molded onto the light's base.
A Harbor Freight magnetic decor hook, two in a pack # 65528, was just a hair too big diameter to fit in the socket, so I just sandwiched it over the existing magnet, thus gaining even more magnetic benefit.
Before putting the magnets together, I first had to trim out the center-holes to access the mounting bolt; and, I had to use a 1/4" bit to drill free the rivet that affixed the hook onto the new, much stouter, magnet.
Of course, the supplied center bolt had to be replaced with one just a shade longer to reach through both magnets.
The package that the magnetic decor hooks came in states that they are "amazingly strong" and that is not an exagerated claim; when I stuck one onto the saw table, I almost couldn't get it loose.
Now, I am not afraid to stick these lights onto any trailer and drive as fast as I want; they will be there when the cows come home.:thumbsup:
One more little detail that I intend to address is to make up about a ten-foot extension pig-tail for those occasions when a trailer is much longer than the supplied cord.
Be it understood that any trailer that I own is well lit and professionally wired; but, for those trailers and such that are not, these magnetic lights are much better than no lights at all. ;)
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #2
I have a set of lights mounted on a piece of aluminum angle that I lay across the trailer deck in the case of a wooden deck and limited amounts of steel upwardly exposed.
David from jax
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #3
Pictures of these super lights? We have a couple of sets that we keep around to throw on the back of the haywagons when hauling them down the road. That way those behind us can see which way we are going.
Aaron Z
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #4
I also have a set of the HF lights, I quess they're not built like the 6 million $ man ..... because they're only an "emergency in a bind fix" :)
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #5
In my area, nobody would question a trailer with messed up lights, and a rental? Pah!
That said, I wouldn't have let them give me a trailer that did not have working lights...that's just wrong on their part. Spend my own money to fix their busted junk? NO way.
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #6
having an extension is almost a must have with those magnetic lights
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #7
thanks for the info about the magnets at HF. I got a set of magnetic lights I built from scratch quite a few years back but never liked the weak magnets. Lights work well, but now I know where to get my magnets. How much did they cost?
I built a set of temporary lights 25 years ago that I used periodically and they worked great. Built them on a 5' piece of stamped shelving angle, the kind with all the holes in it. I worked an auction at a friends farm that was selling out and took my lights over there. A few months later I happened to stop by when the demolition crew was tearing down all buildings. I noticed my one of a kind lights on the back of one of their pickups. I asked where he found them, he told me which building. I asked what he'd take for them. He said they weren't for sale, he had plans for them. I never told him they were mine but I left them behind by accident, figured if he wasn't willing to sell he sure wouldn't give them back...lol. Oh well, that's when I built the magnetic set. And I hadn't missed them until I saw them on his pickup.
   / >>> MODIFIED TEMPORARY TOWING LIGHTS <<< #8
Yep....
I got them, two to the pack, for probably less than $3/pack.
These are labeled "magnetic decor hooks" and have a neat metal hook pop-riveted into the center-hole, which is quite handy in itself if you need a magnetic hook.
A half-a-minute with a 1/4" drill-bit gets that hook gone.
Like a lot of Harbor Freight stuff, I found it interesting that they had the exact same magnets packed singly, no hook, for more money than the packs of two with the hooks. :thumbsup:
Everyone's circumstances are different.
I live in a very rural area, right in the bottom of the welfare bucket of the world, where minimum wage is the most one can ever hope for.
I get by on $160/week; can you ??? :confused:
I needed the back-hoe really bad, I got it from Friday at 3:pM until Monday at 8:AM for the price of one day's rental = $170.
The trailer was a free convenience, as usually they charge a fee for the trailers when you don't have your own.
This is the only place in several surrounding counties that even has such stuff for rent.
Besides, this guy's many businesses probably spends over $200,000/year at my father's business ( be also advised that I don't get a cent of this ); so, I sure wasn't gonna hassle him just because all the rest of his customers destroyed the trailer lights.
It was one of the few rainless/dry weekends that ever happens in Kentucky and I needed the work done that I was able to accomplish, saving me hundreds of dollars as to hiring someone else to do the work, let alone the hassle of me trying to relate JUST what I wanted done; plus, I also took care of several little back-hoe chores that otherwise would have been left un-done.
That trailer having a few light issues was not going to prevent me from acomplishing the task that I had at hand. :)
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
5' MOWER (A52706)
5' MOWER (A52706)
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
2018 FREIGHTLINER CASCADIA SLEEPER (A59575)
2018 FREIGHTLINER...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
