Modified My Hitch
/ Modified My Hitch #1
Mrwurm
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
New Holland class II Boomers with gear drive transmissions and all TC30 models are equipped with a simple clevis and pin type hitch. There is no drawbar that you might use to install a trailer-hitch ball. Here's a picture of the stock setup.
/ Modified My Hitch
The dealer offered to upgrade this to a swinging drawbar for about $300 plus labor. I decided to modify an old ball-mount to attach to the tractor.
Here's a shot of the attachement. I welded some stock to the top and bottom to make it the correct thickness to fit nicely between the flanges on the clevis. I welded on some wings in the back to prevent the attachment from swinging. The original pin from the clevis hitch is shown in a hole that I drilled through the assembly.
/ Modified My Hitch
Here's a shot of the assembly mounted in the clevis hitch. I can remove this part by simply pulling out the pin. I know that there is a considerable amount of 'shear force' placed on the pin, but I don't plan on placing more than about 200 lbs of tongue weight on this hitch. I now use my ball hitch to move my small trailer from the barn (where it's stored) to the driveway when I hitch-up to the van. The trailer weighs 1000 lbs and only exerts about 75lbs of tongue weight.
/ Modified My Hitch #4
as usual the dealers out there are taking advantage the list price on the swing drawbar kit is only 263.00 and it takes less than 15 minutes to put on.
/ Modified My Hitch #5
Just curious, my TC29 (gear driven) came with a swinging drawbar. And I wasn't charged for it as an option.
/ Modified My Hitch
Russ, when I was looking at the TC30 (and complaining about the drawbar) the salesman walked me over and showed me a TC29 gear drive that had the clevis type hitch. From that I made the assumption that all gear drive models came with it. Perhaps this is incorrect.
/ Modified My Hitch #7
I would say your dealer had switched it for someone else because swinging drawbar is standard on all but the tc30
/ Modified My Hitch #8
I think I'm not seeing something. Why will a trailer ball not fit on the drawbar that came with the tractor. Mine looks just like yours and that's what I did.
Eugene
/ Modified My Hitch
I believe that a hitch ball could probably be attached to the existing hitch, but it's so close to the axle housing that I would'nt be able to turn with the trailer attached. The trailer tongue would hit the tires as I turned.
/ Modified My Hitch #10
Hey! Why didn't I think of that! Gotta grind a little to fit a 2" piece of square tubing into mine, but I'm doing it - thanks, Jerry!
/ Modified My Hitch
Cool /w3tcompact/icons/cool.gif /w3tcompact/icons/cool.gif
LEEBOY  1000 PAVER (A67714)
LEEBOY 1000 PAVER...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
DEERE 544K Quick Attach Coupler (A68134)
DEERE 544K Quick...
