Modified Mohawk B-5 Rotary Cutter - How to Return to Safe Use
   / Modified Mohawk B-5 Rotary Cutter - How to Return to Safe Use #1
fourbrads
Peyton, CO
Ford 1910
Greetings! I picked up this Mohawk B-5 "Brave" rotary cutter at a farm near my home. I've already changed out the gearbox fluid and checked underneath to find the stump jumper and blades in surprisingly good condition.
I don't think the upper link area is set up as it would have come from the factory, and would like to return it to something that works well and is 'safe.' I don't have a manual, but it's clear that the top piece of steel (3/8" thick and apparently random length) is a piece of creative engineering. Seems to work okay, but since I haven't pushed it hard yet, I'm not sure what to be worried about. If anything.
Do any of you see any glaring issues that I should address before pressing the old girl into service?
Thanks in advance.
Jim
   / Modified Mohawk B-5 Rotary Cutter - How to Return to Safe Use #2
Make sure the PTO shaft slides in and out freely. If it don't take it apart and grease it.
I would look at changing some of those bolts to grade 8 at minimum if they aren't.
   / Modified Mohawk B-5 Rotary Cutter - How to Return to Safe Use #3
Looks great to me. I've spent many days cutting.
LOT: Misc. Oils, Coolants, Tires (MOST OPENED OR PARTIALLY USED) (A59076)
LOT: Misc. Oils...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
(5) CANDY JARS (A58374)
(5) CANDY JARS...
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
2019 Ford F-750 Reel Flatbed Truck (A56858)
2019 Ford F-750...
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
