Modifications
   / Modifications #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
I wonder is we shouldn't start a sticky that is just dedicated to Modifications. Such a tight community here and honestly there is ton of stuff to search through....
Maybe some sort of easily searchable lines like below....
1850 - Mower - Blade Bolt removal Modification
I cut a hole in my deck to remove broken bolts. A bit of a struggle to find exactly where the hole should be. I then bought a long bolt and welded on a joining nut. This screws down on the threads taht stick up, and then I use an impact to drive out broken bolt out.
   / Modifications #2
Wow!
Thanks for that shade tree mod. That's brilliant; I never would have thought that it might work. I can't wait to try it.
All the best,
Peter
   / Modifications #3
People modify their PT's????
Carl, do you drive the bolt down or are you pulling it up since it no longer has a head on it?
Ken
   / Modifications #4
OK, I made a new thread and made it sticky. Have at it. :thumbsup:
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
Towable Diesel Generator (A59228)
Towable Diesel...
2018 HINO CONVENTIONAL TYPE TRUCK (A55745)
2018 HINO...
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
More info coming soon! (A56859)
More info coming...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
