Modifications to Quick Attach Plate
/ Modifications to Quick Attach Plate #1
Skinnyman
Wilmington, NC
Bobcat CT235
A short time back someone posted and attached pictures of a quick attach plate they modified by adding receiver hitch, and grab hooks. I have tried to use the search function but to no avail. If the person or persons could repost, it would really help me out. I am planning the same thing and liked the ideas I saw.
Thanks
/ Modifications to Quick Attach Plate #2
Thank you, the second link is the one I remember.
/ Modifications to Quick Attach Plate #4
I put a trailer hitch on the loader bucket with the receiver hitch and a 2in ball to move my trailer when i am mower grass.
/ Modifications to Quick Attach Plate #5
QA'a sure area handy. I had a TSC boom pole welded to one. Works great for lifting 300+ pound rolls of aluminum gutter coil through the side door of an enclosed trailer and setting on the machine.
/ Modifications to Quick Attach Plate #6
I am presently 'putting one together'' Have some materials on the way but I had one time made a plywood bucket extension with side,that i used to move yard waste (leaves and the like) it worked good. But now Im using some angle iron from an old windmill and making an aversize bucket. I dont intend to move dirt, just yard waste etc. its basically a frame of angle iron, and will have plywood sides to it.I might even go on the sheap and weld on some home made brackets for the hitch part. that will save 120 dollars on a plate purchase.It is light weight as I said so it wont take much. It will be nice to be able to pop off my bucket and use this one all with the swing of a handle.
My mind is thinking of other things I can make and use the QA for. One is a small platform so I can stand on it and do roofs etc.
Keep the ideas coming..
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
TEREX RL4 LIGHT PLANT (A63569)
TEREX RL4 LIGHT...
2011 JACK  130BBL (A63569)
2011 JACK 130BBL...
Harlo HP6500 (A60462)
Ground Protection Mats (A64047)
Ground Protection...
