Modification to add a 3 point control lever to rear.
   / Modification to add a 3 point control lever to rear. #1
homedad
central/ se michigan
Kubota L3130DT
I have a new to me ck3510 se/c HST because I couldn't afford a CK3520 that already has the rear lever to control the 3 point while connecting implements. Has anyone ever made this modification? I always wished I had one on my open station Kubota and now I really want one on my cab model.
   / Modification to add a 3 point control lever to rear. #2
I like my lever, but you have to be careful not to drop something on your foot! I would see if you can just buy all the parts from Kioti to install it, as you don't want something sketchy rigged up which moves the 3pt unexpectedly.
   / Modification to add a 3 point control lever to rear. #3
This is something I’d really like to do.
   / Modification to add a 3 point control lever to rear. #4
While I don't have a Kioti, I did add the rear 3 pt control lever on my Branson. I'll leave a picture just to give some ideas. All of this is reversible as there is no drilled holes anywhere. Just parts that clamp over the factory ones.
Mine is fairly easy to do as there is pretty much a straight shot to the back. Can't remember how Kioti is setup though.
   / Modification to add a 3 point control lever to rear. #5
I just bought a TYM that has those standard. One small reason I chose this model over the 20 series.
   / Modification to add a 3 point control lever to rear. #6
Here's where it connects on a Kioti DK4210.
You could look under yours and see where the lever from the seat area connects.
Some ideas here: anybody add a rear 3pt hitch lever?
Thanks. I’m going to have to think about this. There isn’t very much visible on Kioti with a cab compared to my Kubota without a cab.
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2014 BMW 320i Sedan (A55758)
2014 BMW 320i...
3 WHEEL ELECTRIC GOLF CART (A55745)
3 WHEEL ELECTRIC...
2020 VOLVO VN SERIES SLEEPER (A55745)
2020 VOLVO VN...
2015 Mitsubishi Outlander Sport SUV (A53424)
2015 Mitsubishi...
