Loader Model M22
   / Model M22 #1
tims0566
MF 135
I just bought a small hobby farm and it has a MF tractor (SN#9A-877I7) and a M22 front end loader. I was trying to find the year and what hydraulic oil is in the loader.
   / Model M22 #2
OK....What you have is a 1970....something.... US built Massey Fergusons of that era shared a common serial number sequence all the way through the model line. Long story short, it could be a 135, a 150, a 165, a 175, or a 180. (or one of several industrial models)
But it IS a 1970 model.
What engine? (3-cyl? 4-cyl?, gas or diesel)
OK again.... Is the loader plumbed into the tractors hydraulics (common oil sump) or does it have it's own pump and res.?
Just from own experience, I've ran Pennzoil HyTran in my Massey Fergusons for many years without the first issue.
   / Model M22
It has a seperate pump attached to front of engine and the right assembly that has the lever controls is the tank and filter. I would like to know where or what filter is needed.
Is there any way to know exactly what model I have as I want to get tune up / other parts. (I.E. Alternator) as it has a starting problem. Battery is not being charged or a short that is draining battery. I haven't had a lot of time to inspect.
It is a three cylinder diesel. I know it's a perkins
Also My Uncle has changed the common sump PTO lever with a three way valve. Unsure what he meant, but the lever being pushed forward kills flow and pump dissenigrates, stick straight up allows 3 point lift to work, and rear puts pump into no flow. Has any one heard of this? I looked in the service manual, but this is not listed.
   / Model M22 #4
3-cylinder Perkins diesel narrows things down considerably. Probably a 135, 150 or a couple possibilities as far as industrial tractors
What transmission does it have?
   / Model M22
3 speed & Hi / Lo lever.
As for PTO pump control that is below seat between legs, It also has on/off for PTO operation
2014 JOHN DEERE 544K LOADER (A51242)
2014 JOHN DEERE...
New Hydraulic Oil Tank With Site Gauge and Filter (A47384)
New Hydraulic Oil...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
(2) UTV TIRES, 215/65-14 (A51244)
(2) UTV TIRES...
Cyclone Rake Yard Vacuum (A50515)
Cyclone Rake Yard...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
