Buying Advice model comparisons
   / model comparisons #1
Soup Can
Cotulla, Texas
John Deere 5103
I am going to buy a new John Deere cab tractor. Based on the size of the implements that I want to buy I have almost decided to buy a JD 6115D.
I was also considering the 5095M. Before I make my final decision I want to get some opinions and advise from some people that have some experience and / or knowledge of these tractors.
I definitely want to buy something in this size range.
What are the pros and cons of these tractors?
Which one should I buy and why?
Is there another model that I should consider?
Opinions and advice would be appreciated, and thanks.
   / model comparisons #2
Both units are a decent tractor. The D series is a basic design tractor and the m series is a premium tractor. The D is obviously a larger tractor, both units use a wet clutch, the M will have more transmission options, the D will lose some Goodies like e pto, eh controlled pto, etc. If you are ok with the basic 9x3 tranny w/ reverser that the D has and need a unit in this chassis I would look at the D series a little harder but am not sure what you are doing with the unit. Fully ballasted D vs fully ballasted M the D will probably weigh about a ton more when all said and done esp if a loader tractor. You are on 2 different bubbles here on 3 point att. The 5000 easily goes between cat I and cat II att. The 6000 easily goes between cat II and cat III. The M will have slightly better hyd performance although neither unit is pressure or flow compensated so probably not that noticable.
3 pt Rolling Basket & Harrow (A50514)
3 pt Rolling...
New Power Line 500 Metal 3pt. Spin Spreader (A50774)
New Power Line 500...
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Kenmore Microwave (A49462)
Kenmore Microwave...
