Model A Transmission Fluid Change
   / Model A Transmission Fluid Change #1
dieselman1967
McDonough, GA
1967 Ford 2000, 1951 John Deere Model A, 1974 Massey Ferguson 150 Diesel
So I went to do an oil change on the transmission of my A and the manual says 27 quarts. I didn't even finish the first 5 gallon bucket before it was over flowing, but about 27ish quarts came out of it when I drained it. Any ideas??
   / Model A Transmission Fluid Change #2
I don't recall for certain, but are there two reservoirs for oil and two fill plugs? Been a long long time..
I've looked over this thing 5 times and can't find another one. I have to be missing something here
   / Model A Transmission Fluid Change #4
Model A transmission fluid change
there is a drain plug located under the drawbar to drain the rear housing .
it is a recessed square .
1995 Vermeer 935 Towable Brush Chipper (A51691)
1995 Vermeer 935...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
2009 40ft High Cube Refrigerated Storage Container (A51691)
2009 40ft High...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
