Model A Transmission Fluid Change
   / Model A Transmission Fluid Change #1
dieselman1967
McDonough, GA
1967 Ford 2000, 1951 John Deere Model A, 1974 Massey Ferguson 150 Diesel
So I went to do an oil change on the transmission of my A and the manual says 27 quarts. I didn't even finish the first 5 gallon bucket before it was over flowing, but about 27ish quarts came out of it when I drained it. Any ideas??
   / Model A Transmission Fluid Change #2
I don't recall for certain, but are there two reservoirs for oil and two fill plugs? Been a long long time..
I've looked over this thing 5 times and can't find another one. I have to be missing something here
   / Model A Transmission Fluid Change #4
Model A transmission fluid change
there is a drain plug located under the drawbar to drain the rear housing .
it is a recessed square .
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2015 Ford Fusion S Sedan (A51694)
2015 Ford Fusion S...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
2005 Ford F-750 Crew Cab Heil 5 Yd Mason Dump Truck (A51691)
2005 Ford F-750...
Pull-Behind Rotary Brush Cutter PTO Attachment (A51691)
Pull-Behind Rotary...
