model 47 snowblower problems
   / model 47 snowblower problems #1
Williez420
John Deere 420 LG
Has anyone had any luck getting a 47 2-stage snowblower to throw better? Mine seems to be a little weak. It, like me, is getting quite a few hours on it and starting to show it's age. The fan seems to be fine, however, the clearance to the housing seems to be about a 1/4" maybe a little more. Any help would be greatly appreciated.
Thanks,
Wm. Brown
1984 JD 420 LG w/ F.E.L.(home-built version of a JD 44)
1992 JD 420 LG
Model 47 snowblower
54" 4 way Dirt/Snow Blade
48" PTO tiller
60" Belly Mower Deck
50" 3-point Mower Deck
48" 3-point Blade
25 Gallon 3-point Sprayer w/ 60" spray bar
   / model 47 snowblower problems #2
:welcome:
Are the impeller blades worn at the tips? Runs in my mind that about the thickness of a dime is needed. Over 1/4" may be too "loose".
   / model 47 snowblower problems #3
I would guess the problem is more about the water content of the snow and the amount of snow being feed into it rather than a mechanical problem. 1/4" or more of clearance between the fan and the shroud is about what a new one has. And, when the blower goes into a drift, that 1/4" of clearance disappears because the snow packs in there.
   / model 47 snowblower problems #4
willie,
which blower do you have on that tractor?
the big ol beast with the gearbox on the back
of the blower housing , or the quick hitch
style with the double chain sprockets?
there may be an issue with your pto drive,
i believe that comes down from the front of
the motor with a belt/pulley setup?
:confused:
2012 VOLVO EC300DL EXCAVATOR (A51406)
2012 VOLVO EC300DL...
2001 Subaru Outback AWD SUV (A51694)
2001 Subaru...
Galvanized Livestock Gates (2x Gates) (A55218)
Galvanized...
UNUSED WOLVERINE PFF3-13-45W PALLET FORK FRAME (A54757)
UNUSED WOLVERINE...
DOOSAN G25KW GENERATOR (A53843)
DOOSAN G25KW...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
