model 3225 Electrical problem
   / model 3225 Electrical problem #1
gel771
Edelstein, IL
Cub Cadet model 3225
Couple weeks ago after mowing, i shut off tractor. hasnt started since, has 12.44 volts @ battery & ignition switch. hop on it push brake turn key: nothing, no dash lights, no crank, nothing!! replaced rectifier & stator last september, started & ran great everytime!! mowed 3 times this sprung & now its dead again......HELP!!!!!!!!!!!!
   / model 3225 Electrical problem #2
few simple things to chk/do:
1. remove batt - take to qualified shop for a LOAD test.
2. while batt out, chk/clean every start circuit elect connection to bright metal with sandpaper. Don't depend on a visual - some corrosion hard to see. Also clean batt ground wire to chassis connection.
3. make sure you are sitting far enuff back on seat to engage seat switch. Or seat switch bad. Cannot just unhook to defeat - replace.
4. jump large posts at solenoid - if engine tries to crank, may be bad solenoid or ign sw. - troubleshoot/replace.
5. if using such, lose garden hose/power washer - L&G tractors don't tolerate moisture well at all - not designed for such (unlike a car). Use compressed/blown air instead.
   / model 3225 Electrical problem #3
Check 25 amp fuse in panel box
   / model 3225 Electrical problem #4
12.44 volts is not fully charged - 12.6 volts is. Does the voltage stay at 12.44 while trying to crank it. Some batteries fail internally and will show good voltage until you put a load on it and then drop to almost nothing. Bad cables give similar results. Check the voltage at the starter.
Bob B.
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
Zero Turn Mower (A48082)
Zero Turn Mower...
2016 Chrysler Town and Country (A50515)
2016 Chrysler Town...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
