Model 226
   / Model 226 #1
mrseddie
Can anyone help me in finding a maintenance manual for this
tractor? Its 3 cyl, 2wheel drive. The brakes are frozen up and I seem to be having a problem getting them apart.
   / Model 226 #2
mrseddie,
I'd say search for member lens12 profile, he has most manuals available. But I can't find how to do a search on a profile now, after the new upgarde to the site.
Jerry
   / Model 226 #4
Not sure what you mean by frozen up or why you can't get them apart, but I would start by saturating the linkage going into the brake housings with a good penetrating oil, if no luck, remove the bolts and gently pry the brake housing covers off with a putty knife or other suitable tool. By the way they are separate modules, make sure you have the pedals disconnected from each other. Maybe only one is stuck.
   / Model 226 #5
I had a YM1110D that had the brakes completely locked up. I couldn't remove the covers because the covers have the shoes mounted to them, and the shoes were bonded to the drums. I had to drag the tractor around with my car until the brakes broke free. Then everything came apart easily.
   / Model 226 #6
Greg, I would assume that is caused by storing for extended periods with the emergency brake engaged. Not a good thing, I suppose.
   / Model 226 #7
No, actually the brakes were working when I pulled the tractor into the garage to rebuild the engine and front axle. They were dragging and making alot of noise, but they were working. When I got it back together, I couldn't budge it. When I finally got the brakes free and took them apart - there was a glaze where the brakes and drums were in contact - even with the brakes off during storage. Now I have to admit that it was over a year sitting there, and its possible that there was moisture in there from before I got the tractor.
New/Unused 7ft 35 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 35...
New Land Honor 5400 LB Ratchet Binder And Chains (A53002)
New Land Honor...
FRONTIER  ROUND HAY BALE SPREADER (A52472)
FRONTIER ROUND...
2021 VOLVO A40G (A52472)
2021 VOLVO A40G...
1991 INTERNATIONAL WATER TRUCK (A52472)
1991 INTERNATIONAL...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51694)
2015 Toro Multi...
