Model 1810 transmission valves leaking
   / Model 1810 transmission valves leaking #1
Bmech
Northern Illinois
Cub Cadet 1810, JD 1010, JD Ztrac 757, 20hp Yardman
I have a model 1810, and the two transmission valves on the top front of the transmission began leaking after I pushed the tractor on a trailer. My question is, are the valves repairable or should they be replaced? I completely dissassembled the trans, and found no damage internally. It drives good, but leaks fluid while running. When the engine is shut down I can hear a burp coming from the transmission valves. New valves are about $150 each, and Iam not sure I want to spend that kind of money on the tractor.:confused:
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2018 John Deere 470G Hydraulic Excavator (A55787)
2018 John Deere...
Shell Vintage Decorative Fuel Pump (A55758)
Shell Vintage...
