Model 1810 transmission valves leaking
   / Model 1810 transmission valves leaking #1
Bmech
Northern Illinois
Cub Cadet 1810, JD 1010, JD Ztrac 757, 20hp Yardman
I have a model 1810, and the two transmission valves on the top front of the transmission began leaking after I pushed the tractor on a trailer. My question is, are the valves repairable or should they be replaced? I completely dissassembled the trans, and found no damage internally. It drives good, but leaks fluid while running. When the engine is shut down I can hear a burp coming from the transmission valves. New valves are about $150 each, and Iam not sure I want to spend that kind of money on the tractor.:confused:
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A52128)
2018 Ram 5500...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51243)
UNUSED INDUSTRIAS...
UNUSED AGT MCMRT14 STAND ON SKID STEER (A51243)
UNUSED AGT MCMRT14...
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
