Model 175 Fuel Cuttoff Extra Wire
/ Model 175 Fuel Cuttoff Extra Wire #1
crawlfish1
Augusta, Georgia
John Deere Model 175
I found an extra exposed connector tucked in the frame just below my fuel cuttoff solenoid. The wire is parallel and attached to the lead that goes to to the solenoid. I haven't found what it's purpose is. Because of the "jagged teeth" it kinda looks like a test connect or something, but I don't like unconnected wires floating around. I've been troubleshooting intermittent start problems and am wondering if this could be grounding against the frame and preventing starting.
Anyone know wht this is?
/ Model 175 Fuel Cuttoff Extra Wire #2
tape up weir for now check connections at battery start solenoid ,key ,brake, pto and saet switches all these will effect tractor starting let us know how you make out thanks good luck
Hello again! Thanks for help here. I've done quite a bit since my post but to sum it up I've got inner tubes in 2 tires, engine and tranny oil changed, new filter, thorough cleaning, mower deck belts and idler bushing replaced, and fresh paint on deck and fender. I'm stuck with what I'll call the deck height selector arm and an extra spring. The spring was hooked under the fender at the selector but was disconnected. My first attempt failed to do what I thought it should so now I'm looking for pics on the proper setup.
207283 (A52708)
207283 (A52708)
2013 Ford F-450 Reading Service Truck (A61573)
2013 Ford F-450...
2020 ISUZU NQR (A63569)
2020 ISUZU NQR...
2014 Kia Sorento SUV (A61574)
2014 Kia Sorento...
2008 UNKNOWN SPOOL TRAILER (A63569)
2008 UNKNOWN SPOOL...
2021 VOLVO VNL860  6X4 T/A SLEEPER TRUCK TRACTOR (A59909)
2021 VOLVO VNL860...
