model 149 cub no fuel to plug
   / model 149 cub no fuel to plug #1
Donsyl
Central Arkansas
Cub Cadet 1811 \and a cub cadet 149
i have a model 149 cub cadet and the fuel comes up into the carb properly but doesnt get to the plug. Does anyone know why? thanks Don
   / model 149 cub no fuel to plug #2
Check float is not stuck some how ....
float is fine, and fuel getting into carb. i have spark and when plug is pulled air blows out of the hole pretty good. dont know why its not enough to get fuel to plug....
   / model 149 cub no fuel to plug #4
How about an intake manifold leak..if the air is leaking around a gasket or something it won't suck thru the carb
The nuts under the valve springs r loose. They shouldnt be should they? Thanks Don
   / model 149 cub no fuel to plug #6
i was just wondering would it run if u spray some fuel in the air cleaner would it run? miy 109 acted the same way but wouldnt start with fuel starter in the air cleaner,come to find out it was the points
I took it back to the guy who rebuilt the engine and he said the head gasket blew so i assume he did not have it torqued to spec and the valves were not adjusted properly
Hawkeye it would not start before when i used fuel or starter fluid in the air cleaner
   / model 149 cub no fuel to plug #9
hey donsly,i take it everything is good to go now?
all good to go Hawkeye
1996 Freightliner FLD112SD T/A Dump Truck (A55852)
1996 Freightliner...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2015 CATERPILLAR  XQ30 GENERATOR (A58214)
2015 CATERPILLAR...
LOT: Clevis Hook, Snatch Block (A59076)
LOT: Clevis Hook...
Mini Skid-Steer Steel Mounting Plate (New/Unused) (A59225)
Mini Skid-Steer...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
