model 1330...no reverse?
/ model 1330...no reverse? #1
keagle
I just purchased a used cub cadet 1330. It's in great condition but it has no reverse. Forward works great, sometimes it will go into reverse a little, but mostly not. Does this unit use hydralic oil? Where do I check the level or fill it?
I know nothing of these mowers:eek:
Thanks for any help!
/ model 1330...no reverse? #2
Check your drive belt tensioner mechanism for worn belt, idler pulley, or spring. Yes, there is a hydrostatic transaxle which holds oil that is driven by the belt. I beleive the fluid on the 1330 is checked and filled by removing an allen plug located above one of the axle housings- check with owner's manual or dealer on that as there were differences among units. There is also a fluid filter used on this transaxle, but it is located inside the hydro pump and is not considered serviceable.
Changing the hydro oil (there is a procedure for it) or topping it off or fixing the tensioner might not solve your problem. The 1330 is an older tractor and I run into a lot of them for sale with weak or dead hydrostatic transaxles. The fluid on these is supposed to be purged and changed every 2 years, but many owners and dealers considered it to be a sealed and non-serviceable unit and did not touch it, thus many are now worn out and not worth repairing.
-Fordlords-
Thanks for the reply! Will check these things out.
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
PALLET OF MISC TRAILER PARTS (A68842)
PALLET OF MISC...
2017 John Deere 331G Compact Track Loader Skid Steer (A66734)
2017 John Deere...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2016 Audi A6 AWD Sedan (A64557)
2016 Audi A6 AWD...
