Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #12
Where did you see that TSC doesn't carry it?
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #13
So you know, JD20D is the same thing. I use JD20C rated trans-hydro fluid because I can get it everywhere.
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #15
All stores show no availability. Last fall I went in and bought 5 gal.
All stores? Mine shows available in-store only. Maybe just in your area?
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #17
Very limited availability, but keep looking. I put a TSC search icon on my desktop and would check a couple times a day when I was ready to buy. Took about 2 weeks for it to show up within travel distance. Immediately made an online purchase, then drove an hour plus to p/u.
I decided to swap out the dealer's Rotella for Delvac while doing my initial 50 hour filter maintenance. Wow, just wow. Whine no more! I have a WRLong third function for my grapple, and whenever I pressed the close too long, it would give a fierce whine. The Delvac put an end to that.
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #19
   / Mobil Delvac Tractor Hydraulic Fluid 124788 and Mobil fluid 424 the same? good/bad #20
(4) 6 LUG GMC TIRES & WHEELS (A51248)
(4) 6 LUG GMC...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
American G-Model Pump Jack (A53473)
American G-Model...
2020 VOLVO VNL64T740 TANDEM AXLE MID ROOF (A53426)
2020 VOLVO...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
