Mobil 1 vs Amsoil Case Study
   / Mobil 1 vs Amsoil Case Study #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
   / Mobil 1 vs Amsoil Case Study #3
Thanks for the heads up.
I always thought, 12 or 15k on motor oil, was a little nutty :cool:
But, it is just one study.
   / Mobil 1 vs Amsoil Case Study #4
And I always thought that 3,000 mile changes were goofy.
I do mine at between 5,000 and 7,500
Id be curious how the Mobil 1 does when they redo it...
IF you wanted a full synthetic oil, i think either one would work pretty well..
NOTE - the charts in the article not correct, they are the same chart for both - the data below them is correct though
BTW - has anyone ever ran a 0wXX to get better gas mileage? Did it work?
Brian
   / Mobil 1 vs Amsoil Case Study #6
Honda civics run a 0W? (5?) for better fuel economy, but they were designed for it. I don't think I would drop this in an engine not designed for it. Bearing surfaces need to be flatter, clearance at seals smaller, or enlarged return lines, etc.
All the best,
Peter
   / Mobil 1 vs Amsoil Case Study #7
I just switched every engine to 0w30 Mobil 1. No data yet. Doubt it will help that much on gas mileage, as I was already using 5w30. Think it gave about a 3% mileage increase vs. dino oils.
The main thing that the 0w30 does is to give your engine better protection at startup when most wear occurs.
Mobil 1 was giving a $5 rebate on the first 5 quarts of it purchased. I sent in for mine.
For those of you skeptical, even a 0w30 oil will be heavier at startup than 30w. So, you're not putting your engine in jeopardy even if it wasn't designed for it. They're all designed for it.
Ralph
   / Mobil 1 vs Amsoil Case Study #8
Just looked at the data. Interesting that metals kind of level off at around 12k. TBN (total basic nitrogen) keeps going down. It's a measurement of corrosivity of the oil, less means the oil can be more corrosive, but the data show that the metals aren't going up after about 12k miles.
In the 31 years I worked in lube oil production design/startup/etc (until 1998). I NEVER heard of Amsoil. Be interesting to know whether they buy their base stock (like Castrol do) or make their own and whether it's from PAO or hydrotreated. Mobil 1 is a true synthetic made from Poly Alpha Olefins destined normally as feedstock for automotive plastics.
Refiners could make PAO from natural gas fields if someone puts in a plant to do so. Normally, they'd probably make it into something like diesel boiling range material to ship it out of the gas fields. However, it would be quite cheap to further refine it to lube oil boiling range and make a lube oil that would be much cheaper than that now made from PAO that is made from dino sources.
Ralph
   / Mobil 1 vs Amsoil Case Study #9
Amen, 3k changes with today's oil? It's all pretty good.
It's got to be a waste of money.
   / Mobil 1 vs Amsoil Case Study #10
I was suprised to see the Amsoil 5w30 turn into 15w40 after 10K. If I wasted to run a 15w40 oil, I would run a good diesel synthetic.... I have never used Amsoil, and that article will keep me with mobil 1...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
1995 Rinker Captiva 190 (A55218)
1995 Rinker...
2006 International 7400 Dump Truck (A47477)
2006 International...
2017 JOHN DEERE Z950M LOT NUMBER 83 (A53084)
2017 JOHN DEERE...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2019 GENIE...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
