Does that model allow you to drive over the MMM with the front tires of the tractor? I think some models do and some don't but you might check the specs on yours. I always hook up the PTO shaft last, because if the MMM is attached you know it will line up correctly with the PTO shaft.
Thanks , lifting tractor with front loader is a big help. Kubota has to come up with a drive over quick attach mower, they are behind the times in this department,
"Kubota has to come up with a drive over quick attach mower, they are behind the times in this department"
I have a B2150 that is over 20 years old with a drive over deck. That said, I think Deere has the system with their auto connect. It attaches the drive shaft wich is always awkward.
