MMM Shakes out of control
   / MMM Shakes out of control #1
Dojogube
John Deere 755
At 2000 rpm my MMM runs fine. As soon as I increase the rpm it shakes uncontrollably. My 755 needs more rpm to function properly. Any ideas?
I WAS going to post a video but I need 3 posts to be able to post a video? SMH.
   / MMM Shakes out of control #2
Make sure the blades are balanced.
   / MMM Shakes out of control #3
No need for a veedeeoo. Inspect blades, pulleys, idlers and belts. Something is either bent, worn or out of alignment.
   / MMM Shakes out of control #4
It's all been said. My JD X750 is electric engagement. Pull the knob and off she goes. Sometimes it will vibrate, a little, at initial engagement but it smoothes right out at operating speed.
   / MMM Shakes out of control #5
Clean the old, dried, caked-on grass from the blades. That will get the whole shebang out of balance
   / MMM Shakes out of control #6
In addition to this list: " Inspect blades, pulleys, idlers and belts. Something is either bent, worn or out of alignment.", also inspect the spindles and their bearings. Yours is doing the opposite of what is normal, getting worse with RPMs.
   / MMM Shakes out of control #7
Agree with all points made. However, I lean toward worn/damaged parts. Typically an out of balance blade while never stopping to shake, reduces with greater rpms.
With your vibration worsen with higher rpms, I really expect a bearing with sufficient wear that the shaft is moving when spinning. Although it well could be a bent shaft as well.
   / MMM Shakes out of control #8
This is another thread where we don't have enough information. How old is this deck? How long has the OP had it? Has any kind of ground object been hit? Did this come on suddenly or gradually?
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2021 Deere 331G (A53317)
2021 Deere 331G...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2007 GMC 2500HD (A56435)
2007 GMC 2500HD...
BUSH HOG 8 SHREDDER (A58214)
BUSH HOG 8...
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
