MMM removal
   / MMM removal #41
Test, sorry..doing the same thing!
Bayrat
   / MMM removal #42
Jeff -
Re the mid PTO covers: go to www.homedepot.com
and do a search on "rubber leg tips". There are some
big ones (1" to 1.5") on the third page which might
work...
Timd
   / MMM removal
During one of my (gee it's nice to not have the kids in tow) walks through Home Depot I came across these items. The diameter would be perfect as I remember as well as the material, but they were all too short to entirely cover the shaft. The only thing I came up with was some pool flexible hose that you would have to put a cap on the end. Don't know why, but I didn't get any to try it. I think I was hoping for something cleaner. Carver suggested looking into a bicycle hand grip (which I think will be too small) or I thought maybe a motorcycle hand grip. Unfortunately I have none on hand and haven't made it anyplace to look at them....yet.
Jeff
   / MMM removal #44
I dont have a cover on my 2910's pto shaft. The only ones I've seen on tractors are the kind that bolt or screw on. I suspect that manufacturers don't put the pop-off kinds on the mid-pto's, as they do on the rear pto's, is because they assume they would constantly be knocked and scraped off, especially when you are in brush. I have been belly up in gooey mud many times, both with the mmm on and off. A hose will easily wash the mud off, and you can add some grease now and then. It really hasnt been a problem.
I lift the mmm with the fel, but you could probably run a chain from the draw hitch over a fence or branch and down to the mower. Better hope that the rear of your tractor is heavier that the mmm before trying this, however.
David White LT6-900 Level Transit, S/N C500926, Model 8834 (A59076)
David White...
Dewalt D28499 7/9" Angle Grinder/Sander (A59076)
Dewalt D28499 7/9"...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2020 DRAGON ESP...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2016 Cat TL1055D Telehandler (A56435)
2016 Cat TL1055D...
