MMM removal, B7800
   / MMM removal, B7800 #1
dmnsmith2
Bronze Member
Alabama
03 Kubota B7800
I know there is a thread on removal of a 60" MMM for the B7800 but i cannot locate. Is there anyone out there familiar with this thread, or would care to share how to easily do this? TIA!!
   / MMM removal, B7800 #2
Lower the deck
Disconnect the drive shaft from the PTO
Disconnect each holding pin from the lift mechanisms.
Unlatch the front hitch bar
Slide deck out the side (very little room to negotiate the path of removal)
Done deal.
However, I raise the front of my tractor up with a hoist and roll the deck out under the front wheels. Makes it so much easier.
Lower the deck
Done deal.
Thank you very much!!
How long does this take?
   / MMM removal, B7800 #5
   / MMM removal, B7800 #7
Lower the deck
Done deal.
Turning front wheels all the way to one side will also give you a bit more room to slide out mower deck and a smooth floor also helps. Jim
   / MMM removal, B7800 #8
I made a platform to lower my mower deck onto.It is roughly 30 x 60 x 3/4" plywood on swivel casters.I roll it under the deck while it is raised,then lower the deck onto it and disconnect everything.It will roll out fairly easy,but I usually go ahead and use the loader to raise the front of the tractor to make it even easier.The casters need to be small so it will not be to tall to roll under the deck.I used some old portable dishwasher casters that I had laying around for years.
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
377780 (A48837)
377780 (A48837)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2009 Ford F-250 Pickup Truck, VIN # 1FTSX21Y49EA41686 (A48836)
2009 Ford F-250...
HEADACHE RACK (A50854)
