MMM question 2520
/ MMM question 2520 #1
xlatin
I have the 2520 with loader and backhoe. How difficult would it be to add a MMM to this? I found a good deal on a barely used MMM , would I have to reroute the hydraulics at the dealership, or is this something I can do. Any kits out there to hook it up manually?
/ MMM question 2520 #2
Do you already have the midmount PTO for the belly mower?
/ MMM question 2520 #3
Welcome to TBN:D
The MMM can be added with the proper hardware/brackets. Not sure what hydraulic lines you are referring to?
/ MMM question 2520 #5
Hi, You may want to check threads for 07 or 08. I have the 2320 set up that way and one of the reasons we went with the 2320 is because some issue with the backhoe bracketry and the mid mount mower. It seems that someone found the issue.
My backhoe frame slides right off. The only thing attached to the tractor are brackets below the steps. Not sure how the 2520 backhoe attaches.
It's been a while so check it out. I would hate to see you purchase something you can't use without modification to the tractor. Maybe there is a work around.
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
New/Unused ATS Cement Mixer (A65583)
New/Unused ATS...
Water Wagon (A64126)
KILLBROS GRAVITY FLOW WAGON (A64277)
KILLBROS GRAVITY...
Red Oak Boards (A65640)
Red Oak Boards...
