MMM question 2520
   / MMM question 2520 #1
xlatin
I have the 2520 with loader and backhoe. How difficult would it be to add a MMM to this? I found a good deal on a barely used MMM , would I have to reroute the hydraulics at the dealership, or is this something I can do. Any kits out there to hook it up manually?
   / MMM question 2520 #2
Do you already have the midmount PTO for the belly mower?
   / MMM question 2520 #3
Welcome to TBN:D
The MMM can be added with the proper hardware/brackets. Not sure what hydraulic lines you are referring to?
   / MMM question 2520 #5
Hi, You may want to check threads for 07 or 08. I have the 2320 set up that way and one of the reasons we went with the 2320 is because some issue with the backhoe bracketry and the mid mount mower. It seems that someone found the issue.
My backhoe frame slides right off. The only thing attached to the tractor are brackets below the steps. Not sure how the 2520 backhoe attaches.
It's been a while so check it out. I would hate to see you purchase something you can't use without modification to the tractor. Maybe there is a work around.
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
Hose Reel (A55758)
Hose Reel (A55758)
2019 ISUSZU NPR BOX TRUCK (A54607)
2019 ISUSZU NPR...
John Deere 3PT PTO Post Hole Digger (A55218)
John Deere 3PT PTO...
INGERSOLL RAND SD-100D VIBRATORY ROLLER (A52705)
INGERSOLL RAND...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
