MMM problem...what to try next
/ MMM problem...what to try next #11
The ones that I have had had a 2 set screw pulley on them.
One where the key is and one approx 90 degrees offset.
If you are going to buy a pulley for it, I would do what County Sawyer said.
Those really aren't bad priced and they won't slip.
BTI
/ MMM problem...what to try next #12
Another alternative: drill and tap your existing pulley to add a second set screw.
/ MMM problem...what to try next #13
Hi-
I saw your post and wanted to check mine to see how that pulley is setup.
I have a DMM60 which is a 60" side discharge deck. In the manual the exploded parts diagram shows a cone shaped spacer type thing (taper lock bushing in the parts list) w/ slot for woodruff key and "plug" (it says plug in the parts list, but I imagine it functions as a set screw). The taper lock bushing's smaller diameter is at the top (engages bottom of pulley) and larger diameter towards bottom. In the parts list, it says it requires 1 taper lock bushing, 1 woodruff key, and 2 "plugs" which I think are set screws. So even though the picture shows one plug, the parts list says two are required. So I imagine my center pulley is held w/ two set screws and hence the reason I probably haven't experienced problems -- although my deck has only about 10 mowings on it. (purchased tractor a few months ago -- it has about 23 hours on it).
Perhaps you could check if the bushing, key, and "plugs" for my deck will work on your deck. Part #'s:
W3021-34171 - Taper lock bushing (1 required)
W3021-33141 - Plug (2 required)
05811-00519 - Key (1 required)
Other numbers of interest:
W3021-33111 - Bevel Gear box - the entire deck transmission
W3021-34162 - Big pulley that's involved with the 3 parts above
If these are compatible with your deck, you may be able to switch to the parts.
Good luck
-Eric M.
CK20 HST
60" MMM Side Discharge
KL120 loader
23 hours
Thx for the reply's and idea's, those part numbers maybe the ticket. I'll have to check with the dealer just to make sure they will work also. thx
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2014 Nissan Rogue SUV (A59231)
2014 Nissan Rogue...
Rhino DB150 (A57148)
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Deere 410L (A53317)
Deere 410L (A53317)
