MMM problem...what to try next
   / MMM problem...what to try next #1
pilonidal
Millmont Pa
CK20 HST
The gear box pulley on the MMM will not stay in place more than 3-4 mowings. It slides down the shaft. When it happened again about 6 weeks ago I replaced the Allen head key screw with a small square head screw so I can really torque it down. I thought no way that is moving. I even took a punch and dimpled the metal on the end to help lock it in place. I always check it before I start as the pulley will set on the deck and still spin, I notice the change in sound from it when it does drop. This time the pulley stayed in place but the pulley key slipped down and was gouging the deck, WTH I thought. I use lock tight on the set screw to. Anyone else have probs with their gear box pulley falling off? The weight of the pulley, vibration and gravity keep pulling the pulley down the shaft. Now I am looking for pulley with 2 set screws, one for the pulley key and one to screw into the shaft. It does make sense to use a pulley with 2 set screws as ultimately only the friction between the pulley key and the shaft are what keeps the pulley in place. Any dealers seen this issue arise?
   / MMM problem...what to try next #2
Your tractor is brand new, right? What's your dealer doing to help? Clearly something's not right.
Well, the deck is 2.5 years old and the dealer whom I purchased it from is 2 hours away. It did this a couple of times last year and more frequently this year.
   / MMM problem...what to try next #4
do you have the side or rear discharge.... never seen the problem. I thought they had to set screws on them. I have both in the shop... will check.
It's a rear discharge.
   / MMM problem...what to try next #6
I believe there are 2 set screws............
BTI
   / MMM problem...what to try next #7
Take the pulley to a good industrial supply house and replace it with one that uses a taper lock from Browning or some such brand. My mowers have taper locks on all of the pulleys and they never move.
   / MMM problem...what to try next #8
I have had the same many times; in fact I’ve had to replace my first pulley as I didn’t catch in time and the key rounded off and elongated the pulley center. My solution has been blue locktight on the setscrew and key as well as a set of t-handled allens for maximum torque on the allen. It also helps to start out with a fresh key. So far it's held through the summer as I last reset it this spring. It is a design weakness and I too have thought of a pulley with two setscrews but abandoned the idea, as I didn’t want to score the shaft so badly as to make removal difficult or replacement necessary.
Regards, Jamie
   / MMM problem...what to try next #9
Make a brass spacer to place over the shaft between the pulley and deck
There is no room for a spacer on the shaft. Guess I'll put some lock tite on the key also. I still want a 2 set screw pulley though. I only have another mowing or 2 before I call it for the year. I am glad that I am not the only one though with this problem. Beginning to think I was an idiot for not being able to keep this darn pulley in place.
The pto shaft to the gear box has a 2 set screws on top where it shouldn't really be much of a problem but the hanging pulley only has one set screw. Things that make you say "hmmmmmm".
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
2020 KUBOTA RTV...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
JOHN DEERE 4100 TRACTOR (A51243)
JOHN DEERE 4100...
Land Honor Quick Attach Hitch Adapter (A50514)
Land Honor Quick...
2008 Kenworth T300 T/A Knuckleboom Crane Truck (A50323)
2008 Kenworth T300...
