MMM lift on 2305
   / MMM lift on 2305 #1
Sprocket1
North Cen. Mo.
JD2305 JD5205
2305, hydraulic lift, 54"mmm. 35hrs. on tractor At slow rpm joystick lifts mower quickly. At mowing rpm mower lifts very slowly. This is a new problem in last few hrs. I haven't changed hyd. oil or filters yet. Please don't tell me the filter is plugged. That would mean deeper problems. Anyone else seen this? Thanks in advance.
   / MMM lift on 2305 #2
I assume by "mowing RPM" you mean your moving. If your moving the hydraulic flow is being split between all things in your 2305 (The hydrostatic drive also). Anything additional you use (Try using the FEL, it'll be slower also than if you are not in motion).
If you are not moving and it actually moves slower at a higher RPM that makes no sense at all. :O)
Sorry, I just realized you said this is a 'new' problem. Not sure what it could be but if it moves quickly at idle it doesn't sound like a clogged filter. Does the FEL move normally?
   / MMM lift on 2305 #3
I have A seperate mmm Hydraulic lift on my Deck I had installelled From the dealer ! That way The 3pt hitch & The 54" mmm Are on seperate Hydraulics No problems here it really makes A difference !
2016 Hyundai Tucson (A53424)
2016 Hyundai...
Booster Cables (A55852)
Booster Cables...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2017 Kia Sorento SUV (A53424)
2017 Kia Sorento...
