MMM lift on 2305
   / MMM lift on 2305 #1
Sprocket1
Bronze Member
North Cen. Mo.
JD2305 JD5205
2305, hydraulic lift, 54"mmm. 35hrs. on tractor At slow rpm joystick lifts mower quickly. At mowing rpm mower lifts very slowly. This is a new problem in last few hrs. I haven't changed hyd. oil or filters yet. Please don't tell me the filter is plugged. That would mean deeper problems. Anyone else seen this? Thanks in advance.
   / MMM lift on 2305 #2
I assume by "mowing RPM" you mean your moving. If your moving the hydraulic flow is being split between all things in your 2305 (The hydrostatic drive also). Anything additional you use (Try using the FEL, it'll be slower also than if you are not in motion).
If you are not moving and it actually moves slower at a higher RPM that makes no sense at all. :O)
Sorry, I just realized you said this is a 'new' problem. Not sure what it could be but if it moves quickly at idle it doesn't sound like a clogged filter. Does the FEL move normally?
   / MMM lift on 2305 #3
I have A seperate mmm Hydraulic lift on my Deck I had installelled From the dealer ! That way The 3pt hitch & The 54" mmm Are on seperate Hydraulics No problems here it really makes A difference !
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
2004 Ford F-250 Pickup Truck (A50323)
2004 Ford F-250...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
Kubota KX033-4 Midi Excavator (RIDE AND DRIVE) (A50774)
Kubota KX033-4...
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
