RaydaKub
Veteran Member
Sorry you are still having issues. I use my FEL to lift the front wheels off the ground. That allows me to keep the front fork on the mower as I push it under the tractor. Next I slide the collar back, then feed it through the plate opening with my left hand from the left side. I put my right hand in under the brake rod above the plate to align the splines on the shaft. I can turn my mower with my left hand on the shaft if I need it. I do this by feel more than by look. Once it starts on the shaft, I can usually wiggle it on with my left hand. Once the shaft is on, I drop the front wheels down, hook the lift arms, then hook the fork to the front latch. Having the front wheels up does give you the small issue that you may need to yank the mower backwards after lowering it to line up the lift arms.
Don't give up yet. It does get easier. It did for me.
