Mowing MMM Cutting Height Adjustment Slips
   / MMM Cutting Height Adjustment Slips #1
aslusar
Kubota BX2200
I have a Kubota BX2200 with a 60" MMM. The mower is properly installed and adjusted for height. I have used this setup happily for about 3 years, however, at the end of last season the mower started slipping into lower height settings while mowing. I normally set it to 2.5 inches, but over time it will slip down to 2", 1.5" or 1". Does anyone know how to fix this problem?
Thanks,
Andy
   / MMM Cutting Height Adjustment Slips #2
I just posted, http://www.tractorbynet.com/forums/kubota-owning-operating/206620-bx-60-mmm-does-not.html, about my mmm doing the same thing on my new BX2660. E171fish in my post lead me to two different threads that discuss the same issue. For the B series there is even a product issue bulletin and it describes the repair procedure.
I did contact Kubota customer service and they told me that the fix is to use the 3 pt speed control and lock the 3 pt hitch in position. But I believe that this would just be a band aid and not a proper repair.
I did look at my cam adjuster, by removing the left rear tire, and the steps in the adjuster already look worn.
I am planning on taking my tractor in after the mowing season to have warranty work done on the tractor.
I hope that these posts help.
Thanks Sammy KY the other posts were helpful. By the looks of the adjustment gear on my BX2200 it needs some work.
Super Star Smithco Bunker Rake (A50322)
Super Star Smithco...
2015 Ford Econoline Shuttle Bus (A50323)
2015 Ford...
2015 International 4300 Dura Star Box Truck (A47384)
2015 International...
2014 E.D. ETNYRE & CO CENTER DROP HOT OIL TANKER TRAILER (A47384)
2014 E.D. ETNYRE &...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Case-IH 370 Steiger (A50120)
Case-IH 370...
